History of Sensor RCD Modules
RCD History
ETC has been producing RCD modules for Sensor and Unison racks since the early 1990s. There have been several changes to the design over this time – this page provides a guide to how to identify the type of RCD you have.
In order to identify an RCD, power down the rack and remove the module(s). Look at the right-hand side of the RCD breaker assembly in order to view the side of the circuit board.
Picture Version Notes
clipboard_e665b51d67ea5e4ba0a04813982e4ff48.png RCD 1, 2, 3 Identify by green circuit board. In order to identify the specific generation, use the part number on the white PCB label.
clipboard_ebecb8df860a573039c1be4ef797e5ad9.png RCD4 Blue circuit board, no marking between ICs
clipboard_ecc205fbd45d3cc35a5cee7cebce41ddd.png RCD5 Blue circuit board, "RCD 5" between ICs on board
Part Numbers
The most common RCD part numbers are shown below.
RCD 3
Current Rating
Trip Rating (IΔn)
ETC Part Number
6A
30mA
7070A2125
10A
30mA
7070A2126
15A
30mA
7070A2105
25A
30mA
7070A2107
50A
30mA
7070A2109
RCD 4
Current Rating
Trip Rating (IΔn)
ETC Part Number
6A
30mA
7070A2225
10A
30mA
7070A2226
15A
30mA
7070A2205
25A
30mA
7070A2207
50A
30mA
7070A2209
RCD 5
Current Rating
Trip Rating (IΔn)
ETC Part Number
6A
30mA
7070A2325
10A
30mA
7070A2326
15A
30mA
7070A2305
25A
30mA
7070A2307
50A
30mA
7070A2309
Servicing RCDs
RCDs should have their functionality tested periodically by pressing the “TEST” switch on the module. Regularity of testing depends on electrical regulations in your country; ETC recommends at least a quarterly test.
Exchanging RCDs
If you need to replace an RCD due to failure, ETC recommends a complete module replacement. It is not recommended to repair or exchange an individual RCD as it is a safety device.
