Replacing Broken or Damaged Sensor Lug Retainers
The Sensor dimmer load lugs on the right side of the rack are held in by a small plastic clip on the lug terminal block. If this clip breaks the lug may come out with the dimmer module. The only acceptable long-term method of resolving a broken clip on a Sensor terminal block is to replace it.
When the block tab is broken a short-term fix for holding lugs in is to slide the lug into the plastic then install the module.
If there is any other damage it will need to be replaced immediately. Contact your local Authorized Service Provider.
