Touring Rack work light replacements
Original Work Lights
These were strings of small gang of white incandescent lamps with fine wire connecting them together. After several years these lamps would burn out.
LED Retrofit Kits
These kits were designed to change out the metal, and changed to a new work light and driver using LEDs molded to wire.
  • 7143K1006 - 4820 Touring rack LED Retrofit kit (Small frame with patch bay)
  • 7143K1007 - 9620 Touring rack LED Retrofit kit (Large frame with patch bay)
  • 7143K1008 - Double Small 9620 Touring rack LED Retrofit kit (Small  frame 2 columns of dimmer)
