Model Number Structure - Pantograph Cable Management
Distro Mount Pantograph
  • When the pantograph assembly ships attached to, or will be installed with, standard distro, the distro model number ends in -PT to indicate the included Pantograph Cable Management System.
    • Example: 9945-(12BO/12)(1X/1)-PT
Standalone Pantograph
  • When a standalone pantograph assembly is provided on a project with bare end festoon cable at the bottom of the pantograph or terminates at a terminal box or outlet box the following model number structure should be used:
    • PTH-C-LV
      • PT = Pantograph Cable Management
      • H = Pantograph Height
        • Total Dead Hang + Travel height
      • C = Quantity of Circuits
      • LV = Quantity of Low Voltage
        • Follows Standard Distro LV model number structure: 1X, 2X, 1N, 2N, etc.
    • Example: PT50-12-1X
