Position - Odd Readings or Trouble with Soft Limits
If you have commissioned the system and are getting odd position readings on the QuickTouch controller such as when going up the numbers start to read negative or the hoists stops a random spot and reports that it is at a soft limit.
Is this occurs please call tech support or your rigging dealer.
