Joystick Calibration - Foundation
If the joystick on the Foundation is not operating as expected you will need to re-calibrate it.
Steps to Solution
- Log out of the controller
- Press shutdown
- Press the exit button - you are now in the shell
- Press and hold the Maintenance button for 10 sec.
- Go in to the tools tab
- Press the face panel tester button
- In the center left of the screen is the joystick calibration
- Press the clear button
- With the joystick in the center position press the center button
- Push the joystick away from you till it stops and press the up button
- Pull the joystick toward you till it stops and press the down button
- Press the red 'X' button on the top right corner
- Press the close button on the bottom right corner
- press the 'Launch Foundation' button to restart the controller
