Hog 5 Console is not connecting to visualizer
A Hog 5 console is not detecting a supported visualizer, and you want to use the Visualizer Stream from Hog 4 OS.
The visualizer computer is connected to the HogNet Port
OR
IP addresses are not in the proper range
OR
Fixtures are not patched in the Console or in the Visualizer software
  • Make sure that the visualizer computer is connected to the FixtureNet port
    OR
  • Make sure that the FixtureNet IP is in the same range as the visualizer computer's IP address and that the HogNet IP is not in the same range as the FixtureNet.
    OR
  • Make sure that fixtures are patched both in Hog and the visualizer
Example of a working setup:
  Console Visuallizer
FixtureNet IP Address 10.0.0.1 10.0.0.101
Netmask 255.0.0.0 255.0.0.0
HogNet IP Address  172.31.0.1 -------------------
