PCBs, Playback and Program board correct part numbers, Full Boar 4, Hog 4, and Hog 4-18
The part numbers silk screened on the PCBs are not the correct part numbers. They have not been programmed and will not work.
Use the part numbers below
- For Hog 4 Playback PCB, use part number 80040050EF
- For Full Boar 4 Playback PCB, use part number 80040083EF
- For both Full Boar and Hog 4 Program PCB, use part number 80040048EF
