Remove fixtures from multiple cues in Hog 4 OS
Fixtures are programmed in multiple cues and all the information for those fixtures needs to be removed from multiple cues.
  1. Select the fixtures
  2. ( Touch )
  3. [ Record ]
  4. ( Remove )
  5. Make sure Track Forward and Track Backward are not selected
  6. Starting Cue Number [ Thru ] End Cue Number
    This will only affect the chosen master. To remove from a different list: [ List ] Starting Cue Number [ Thru ] End Cue Number [ Enter ]
  7. [ Enter ]
The command line and options should look like the image below if trying to remove fixtures from cues 1 through 3 on the chosen master
Command Line and options
