Cyberlight LED Tilt moves slightly back and forth
Mirror tilts slightly back and forth
The encoder is not reading the tilt movement correctly
  1. Check the set screws on the tilt hub
  2. one set screw is for the tightening to the motor shaft, the other is to tighten the split hub
  3. tighten both set screws to insure no slippage on the shaft of the tilt portion of the mirror head movement
