All Halcyon Gold Software Versions
NOTE: Be cautious when downgrading fixture software versions as this can affect many functions such as cooling/thermal adjustments, power adjustments, DMX channel count and the overall functionality of the product. HES recommends always updating to the latest version of released software.
The most recent release can be found on the Halcyon Family product page at:
https://www.etcconnect.com/Products/Automated-Lighting/Halcyon/Software.aspx
If you need an older version of the software, contact ETC Technical Support.
Version Release date Fixes Download link
v1.3.1 10/11/22
  • Initial production release
v1.4.1 01/18/23
  • First web-published version
  • Fixed bug relating to accuracy on Pan and Tilt when using Magnetic Sensor
v1.4.3 05/10/23
  • Display invert text redraw issue corrected
  • Response to non-zero start code corrected
  • Improvements to fan control
  • Color Linear CMY curve made default
v1.4.4 06/07/23
  •  Pan/Tilt encoder feedback times out when fixture is held out of position.
  •  Pan/Tilt homing issue when using effect engine fixed.
  •  Pan/Tilt position error when switching pan range from 540 to 630 fixed.
  •  mSpeed added to gobo and color functions.  New fixture library needed to access.
  •  Park current of motors reduced.
  •  Start up fan voltage adjustments made.
  •  Fast mode added to CMY/CTO color mixing.
v1.4.6 06/21/23
  • Park current adjusted on prism mototrs
v1.4.7 07/17/23
  • Park current adjusted on frost motors
v1.4.8 07/24/23
  • Pan/tilt mSpeed off was added to the control channel
  • Fix for network communication issue when running multiple universes of Art-net and sACN
  • Errors Detected" message added to display after homing with an error.
v1.4.9 08/29/23
  • Follow spot mode selection added to fixture menu.
  • Improvements made to fan control.
v1.4.10 12/04/23
  • Magnetic Mode encoder time out issue corrected.
  • CMY curve selection moved in the menu. It is now in the settings branch of the menu, in between Gobo Color Correction and Temperature Units.
  • CMY curve selection added to library for access thru the console.
  • RDM labels added for temperature monitoring
v1.4.11 12/14/23
  • Bug causing display to turn on after being turned off from console fixed.
v1.4.12 02/20/24
  • Autofocus calibration moved to settings in menu.
  • FSM displayed when in follow spot mode.
v1.4.13 04/22/24
  • Pan/Tilt curve selection added to menu and control channel. (S-curve/Linear).
  • Adjustments made to fan control.
v1.4.15 06/19/24
  • Park current on focus motors increased to prevent mis-step.
  • Fixture software version and temperature menus moved to the first two options in Diagnostics.
  • Bug fix causing erroneous pan error after uploading.
v1.4.16 07/18/2024
  • USB upgrade issue causing some USB drives to not be detected fixed.
  • Adds dual backup sectors to make sure fixture hours are saved.
v1.4.17 07/25/2024
  • LED cooling fans starting voltage adjusted for fan tolerances
v1.4.18 08/29/2024
  • Gobo wheel spin and rotate function speeds adjusted to prevent mis stepping
Halcyon Gold_V1418.NCW - USB
Halcyon Gold_V1418.HYD - Uploader
Halcyon Gold-Ver-1-4-18.zip - All files
