Halcyon Gold Focus, Frost, Prism, Prism2, Prism2 Rot, Prism Rot, Zoom, Frost not working after replacing bracket
Symptoms
Issue or malfunction of the Focus, Frost, Prism, Prism2, Prism2 Rot, Prism Rot, Zoom, Frost functions after replacing metal bracket.
Description
If you installed the long screw (1 of 3 on each side) the 5U board may short causing the above functions not to work. The board will work if you move the screw to the outside where it will not touch the leads on the board connector.
  1. Swap the longer screw shorting the board for the two shorter screw, then board shourd resume working
