Halcyon Power Supply Wiring
Halcyon output power supply terminal labels do not match the wire harness.
Explanation of Issue
The 48v +/-  and 28v +/-  wire labels are confusing if not noted before swapping power supply. If plugged in incorrectly multiple components may be damaged due to improper voltage.
  1. Note the quantity and voltage of wires in each terminal
  2. Take photo prior to removing power supply
  3. Double check new power supply is installed and wired correctly prior to powering on the unit
DC Wiring:
Blue is -
Red is +
48v+
(x2)
48v+
(x1)
48v-
(x2)
48v-
(x1)
28v-
(x2)
28v+
(x2)
V1
V1
V2
