Output Lens Different on 18 Halcyon Graphite Units
18 units were built with the first version of the output lens.
Explanation of Issue
These serial numbers have a spacer between the lens and its mounting plate labled Old in the image below: 732026080002; 732026080004; 732026080029; 732026080059; 732026080069; 732026080073; 732026080074; 732026080075; 732026080076; 732026080077; 732026080078; 732026080079; 732026080080; 732026080081; 732026080082; 732026080083; 732026080084; 732026080085
  1. If a replacement output lens is needed, the new lens has the spacer integrated. See the image below labeled New.
  2. Do not use the spacer when installing the new output lens
