Shapeshifter Module Not Homing Correctly
One of more modules does not home correctly and are out of alignment
The module(s) is out of coplanar and needs to be adjusted
- Watch the attached video starting at 2:39 for instructions to properly set coplanar : RDM 2.6 _9-10-14.mp4
- More details about coplanar can be found on the Shapeshifter support page: https://www.etcconnect.com/Products/...peshifter.aspx
