Updating Solawash 2000 HCRI After Flag Module Conversion
Older Solawash HCRI software versions do not have have the color mix flag option in the menu. This only applies to the Solawash 2000 HCRI fixture.
If a unit is converted from wheel color mixing module to a flag color mixing the module type must be changed in the Set>Status> CMY Type menu.
  1. Update to the attached software version
  2. Change the module type after updating
