Shapeshifter Module Not Homing Correctly
One of more modules does not home correctly and are out of alignment
The module(s) is out of coplanar and needs to be adjusted
  1. Watch the attached video starting at 2:39 for instructions to properly set coplanar : RDM 2.6 _9-10-14.mp4
  2. More details about coplanar can be found on the Shapeshifter support page: https://www.etcconnect.com/Products/...peshifter.aspx
