Will not home after sent global reset command on EOS console
After a Lonestar has been sent a shutdown command it will not home when sending a global reset command. This can happen on any EOS console.
The wait time to zero out was too short after sending the global reset command.
- This has been fixed in the latest fixture library which can be downloaded from here: https://www.etcconnect.com/Products/.../Software.aspx
