SolaFrame 1000 Changing LED Engine Type on Display
After a SolaFrame 1000  has had an LED engine conversion either from HI CRI/Hi-Fidelity to Ultra Bright or vice versa the latest software should be applied to the fixture.
After doing so, you may still see the original fixture description on the display upon homing.
To change this via the fixture menu:
MENU > SET > Service Setting > Service PIN > 050 > LED eng type > Toggle to the correct engine type > ENTER
