SolaSpot 1000 Animation Wheel Replacement
PDF Version: SolaSpot 1000 Animation Wheel Replacement.pdf
Applies to: SolaSpot 1000
What you will need: New animation wheel assembly, Philips screw driver
Step One: Remove Head Covers & Gobo Module
· Loosen 2X Philips 1/4 turn captive screws on each head cover
· Detach safety cables and remove covers
On the non-lock side of the fixture’s head:
· Disconnect power and data wire connections
On the lock side of the fixture’s head:
· Remove 2X Philips head screws
· Lift up on the zoom/focus assembly to clear a path for the module
· Carefully Remove the gobo module
Step Two: Remove Animation Wheel Assembly
· Remove 4X Philips head screws to free the animation wheel assembly (wheel, metal arm & belt)
· Reuse hardware
Step Three: Installing New Animation Wheel Assembly
· Ensure that the belt is traveling on the inside of the tensioner
· Place the belt around the motor
· Replace 4X Philips screws to mount new assembly
Ensure that the wheel can travel/spin without making sound or without issue (it is normal to feel steppy by hand)
