Solaspot 3000 Animation Wheel Rework if Moving Up and Down While Rotating
Solaspot 3000 metal animation wheel moves up and down when rotating. Example video: SS3K_01.wmv
This is due to interference between rotating and revolution spinning on drive gear. When animation wheel engaged, it will cause the wheel arm to move up and down, this results in the animation wheel arm moving orthogonally when it is rotating
1. Order the upgrade kit. Part number 2581A2080
2. Follow these instructions for the update: SolaSpot 3000 Animation Wheel Module Rework.pdf
