How Do You Program the Echoflex CAN2GO BACnet Gateway
Question
How do I go about programming my Echoflex CAN2GO BACnet gateway?
Answer
The CAN2GO gateway is a third-party interface Echoflex uses for BACnet purposes. The gateway is programmed using LUA scripting via a networked web server interface, not via any typical Echoflex programming methods. At this time, unless you are very familiar with this style of programming and all the systems that need to communicate, you will need to have this unit pre-commissioned before installation.
