Status Messaging or Telegrams with Echoflex Interfaces
Question
Is there a way to monitor the current status of an Echoflex Controller or Interface?
Description
Normally, Echoflex communication is a one-way street, with control devices sending signals to output controllers and interfaces that count as outputs. Status messaging is a special case that allows an output controller/interface to report its current status, which serves two main purposes:
  • To allow a user to monitor and interpret the status via Garibaldi Pro or DolphinView to assist with troubleshooting equipment.
  • To provide feedback to interfaces/gateways that use that status to trigger other commands.
This feature is disabled by default and can be enabled/disabled via the physical buttons on the unit or the Garibaldi Pro commissioning program.
Manual Steps at the Device
To enable:
  • Press and hold the [LEARN] button.
  • Tap the [CLEAR] button twice.
  • Release the [LEARN] button. The "learn" LED should blink twice to confirm the double tap.
To disable:
  • Tap the [CLEAR] button once.
  • Release the [LEARN] button. The "learn" LED should blink once to confirm the single tap.
Video Walkthrough
