Description
The Unison Echo®-Echoflex interface (EEI) uses a MicroSD card for firmware upgrades. At the beginning of an upgrade, the EEI will blink its status or error lights in different patterns, depending on what is happening.
State
Status LEDs
Error LED
Bootloader resident
Blink, blink, none, none
Off
Writing firmware to flash
Blink, blink, blink, none
Off
Bootloader error
Off
Flash checksum error
Off
SD Card Error
Off
Blink, none, none, none
While the upgrade is happening, the Status LEDs will blink (as per "Writing firmware to flash" above) and the LED bar graph will light up sequentially. This process typically takes less than a minute.
When the upgrade is successful, the EEI will return to normal mode. Be sure to remove the MicroSD card at that point.
