How do I Enable Occupancy Control for Echoflex Sensors?
Some definitions first
- Vacancy Control = Lights shut-off automatically upon vacancy after a timer expires
- Partial-OFF = Lights dim down to a set level automatically upon vacancy after a timer expires
- Occupancy Control = Lights turn-on immediately upon occupancy detection
- Partial-ON = Lights turn-on to a set level immediately upon occupancy detection. The level may be determined by applicable energy codes
Cycle the output = Lights blink off and then on at full. Output is not expected to return to previous level when this happens
I have a sensor and switch station linked to my controller and now it only performs vacancy control. How do I enable occupancy control?
Description
Echoflex controllers will automatically configure as vacancy control (Manual ON - Auto OFF) when you have a switch station and sensor linked. It does not matter in which order they were linked.
If only a sensor(s) is linked and no switch stations, the controller will enable occupancy control (Auto ON-Auto OFF) automatically.
Be Aware!! If you are using the OWS-DT Wall Sensor, the switch and sensor are linked to the controller as two separate devices. You will need to link both devices to the controller individually. Instructions for these processes in included in the OWS-DT install guide.
Enabling occupancy / vacancy control or partial-ON, partial-OFF can be performed without any special tools. However you will need access to both the wall station and sensor and if you're working alone, it may be more convenient to remove one or the other from the mounting location and take with you to the other device.
Enabling Occupancy or Setting the Partial-ON Value
- Turn the lights ON
- in the case of setting partial-ON, use the switch to dim the lights to the desired level for the partial-ON setting
- Press the TEACH / LINK button on the sensor. You may have to remove the cover depending on the model
- Within five seconds, press the ON side (button or paddle) of the switch station four times. The controller will cycle the output once to confirm the change
NOTE: To disable Occupancy or Partial-ON and revert to vacancy operation, replace step 3 above with:
Within five seconds, press the ON side (button or paddle) of the switch station three times followed by one press of the OFF side. The controller will cycle the output once to confirm the change
Setting the Partial-OFF Value
- Turn the lights ON and use the switch to dim the lights to the desired level for the partial-OFF setting
- Within five seconds, press the OFF side (button or paddle) of the switch station three times followed by one press on the ON side. The controller will cycle the output once to confirm the change
NOTE: To disable Partial-OFF and revert to vacancy operation, replace step 3 above with:
Within five seconds, press the OFF side (button or paddle) of the switch station four times. The controller will cycle the output once to confirm the change
Dual Tech sensors have their own internal timer. By default controllers have a 900s timer. Dual Tech sensors have a 1200s timer. One could view the 20-15=5 minute window as an extended grace period for audio events. If you are using Auto – ON with a dual tech sensor you should set the controller timeout to 0 and use the sensors timer. This way the grace period lines up properly with the audio (and is title 24 compliant).
Related Links
Video Walkthrough
