DAS Troubleshooting
Problems Cure
No Response to Button push
S2 (Reset) switch needs to be replaced
On LCD station - All Black bars that don't go away
No response to button hits, and one of the PRESET LED's flashes every so often. On LCD stations - Waiting for Data Link
U2 is bad. Thumbwheel switch is set to wrong address
Certain buttons work, other do not
Switch contacts are dirty
Fader doesn't respond or brings up more channels than expected
Pot is bad. A/D converter is bad.
Crystal (Y1) is damaged or bad.
Station is dead
VR1 is damaged or bad. This can get damaged when the station is stuffed into it's backbox.
No communication between EMAP and stations
Check U32 (Z216-F) in the EMAP.U46 and U47 are spares. PN# Z1458-F works as replacement.
Check U2 (Z216-F) in the stations. PN# Z1458-F works as replacement.
- on older boards the designation may be “Z” instead of “U”
Random Lights are on or flickering
Deep Clear the EMAP by jumping pins 7 & 8 on J3. Hit Reset and remove jumpers. Hit reset again.
Notes
  • To Reset: Take Fuse out and put it back in (top right hand corner of ARW).
ETC  Legacy Data Termination Guide Diagram
