Echo Devices That Can Enable or Disable Remote Record
Background
Disabling or enabling Remote Record on an Output Product in an Echo system is not a global setting.
When the Record function is disabled on an Output Product, that single device ignores all incoming Record commands. This behavior is not automatically altered in other Output Products in the Echo system.
Devices with Adjustable Remote Record
Below is a list of devices that have adjustable remote record features.
By default, Remote Record is enabled.
  • Echo Architectural Control Processor (E-ACP)
  • Echo Relay Panel (ERP and ERP-FT)
  • Sensor IQ (SIQ)
  • Sensor 3 (CEM3)
Devices with Fixed Remote Record
Some Echo Output Products use remote recording to function, so disabling Remote Record is not an option.
  • Echo DMX Scene Controller (EDMXC)
  • Echo Room Controller  (ERMC4 / ERMC8)
  • Echo Relay Controller (ERC and EDRC)
  • Echo 0-10v Controller (ELD and EDLD)
  • Echo Smart Space Controller (ESSC and EDSSC)
  • Echo Phase-Adaptive Dimmer (ELVD)
  • Echo Forward Phase Dimmer (ELVD-MLV)
  • Echo Touch Controller (ETS)
5-button and 10-button Echo Preset stations have record functionality built into them by default as a long press of their preset buttons. As a result,  if a Echo Preset station running firmware below 3.0.0 is used with a fixed Remote Record device, it is not possible to disable the station press-and-hold record functionality.  This default functionality can be changed in Echo Preset stations running firmware v3.0.0 and above by using an EchoAccess.
