Echo Preset Limitations
Echo Output products (Relay Panels, Zone Controllers, and other Power Controllers) support a minimum of 8 presets.
Different Output products may support larger numbers of presets, as follows:
Output Product Number of Presets
Echo 1- and 2-Zone Relay Controller (ERC, EDRC) 8 Presets
Echo 1- and 2-Zone w/ 0-10v Controller (ELD, EDLD) 8 Presets
Echo 1- and 2-Zone SmartSpace Controller (ESSC, EDSSC) 8 Presets
Echo Phase-Adaptive Dimmer (ELVD) (120v and 277v) 8 Presets
Echo 1- and 2-Zone Relay Controller Gen 2 (ERC-G2, EDRC-G2) 16 Presets
Echo 1- and 2-Zone w/ 0-10v Controller Gen 2 (ELD-G2, EDLD-G2) 16 Presets
Echo 1- and 2-Zone SmartSpace Controller Gen 2(ESSC-G2, EDSSC-G2) 16 Presets
Echo Phase-Adaptive Dimmer Gen 2 (ELVD-G2) (120v and 277v) 16 Presets
Echo Room Controller (4- and 8-Zone) (Gen-1 and Gen-2) 16 Presets
Echo Contact Output Interface (ECOI) 16 Presets
Echo DMX Scene Controller (EDMXC) 32 Presets
Echo Relay Panel Feed-Thru (ERP-FT) 64 Presets
Echo Relay Panel Mains Feed (ERP) 64 Presets
EchoDIN Power Control Processor 64 Presets
Echo Architectural Control Processor (in Unison DRd) (E-ACP) 64 Presets
Sensor IQ Intelligent Breaker System (SIQ) 64 Presets
EchoTouch Controller (ETS) 64 Presets
CEM3 Power Controller (CEM3) 128 Presets
An Echo “Output Product" is a power controller that can store preset levels for the outputs it drives.  Output Products are controlled by Echo “Control Products” such as button stations and light sensors.
Echo Devices that activate presets default to starting at Preset 1 but can be changed to have a different starting number.
  • A Device that can only activate a single preset (such as an Occupancy Sensor) can be programmed to activate any preset number up to 64.
  • A Device that can activate one of several presets may be programmed to start so that its last preset is as high as 64. For example, a 10-button station’s first preset can be set as high as 55 so that it controls presets 55 - 64. A 4-button station’s first preset can be set as high as 61 so that it controls presets 61 – 64.
  • The EchoAccess Mobile App can only activate presets 1-16.
  • All Echo Output Products have default levels for these presets pre-recorded.  Preset 1 = All Zones at 100%, Preset 2 = All Zones at 75%, Preset 3 = All Zones at 50%, Preset 4 = All Zones at 25%.  This cycle repeats itself every 4 presets, so Preset 5 = All Zones at 100%, Preset 6 = All Zones at 75%, etc.  The Echo Contact Output Interface is an exception to this rule.  For this product, all odd numbered Presets, when activated, will close all relay outputs and all even numbered Presets, when activated, will open all relay outputs.
