Echo Space Combine Not Working When Space Lockout is Active
If using an Echo 4 button Inspire station in Space Combine mode and also utilizing Space Lockout, whether with an Echo lockout station or via the EchoAccess App, it is possible that the Space Combine station may lock out as well. This means that you will need to unlock the space(s) that are locked to un-combine or further combine spaces.
 This is a bug in v3.0.0 of the Echo Inspire station. Any station v3.1.0b or higher will not have this issue.
