Can You Patch Channels Across Multiple sACN Universes on EchoTouch?
In the Patch display, if you try to edit the Universe of a channel, your change will not be accepted.
Explanation of Issue
EchoTouch only allows patching to one sACN universe at a time. This universe is not defined in the Patch display (you can only assign channels to Universe 1), but the sACN universe that patched channels will output to is defined in the Setup -> Settings -> Network tab under Network Universes.
