Original E-PCP vs PCP Mk2
Question
How do I know if I have the original processor or the Mark 2 (Mk2) version?
Answer
The easiest way to know which processor you have is by looking at the front of it. The Mk2 unit will have a label in the bottom left corner, underneath the LCD screen, that says "PCP Mk2".  The original version of this processor had no label here at all.
Original E-PCP PCP Mk2
Additional Differences:
  1. Mk2 processor will have an RJ45 Ethernet port on the back of it.  Original processor will not.
  2. Mk2 processor will run firmware version 4.0.0 and up.  Original processor cannot load firmware above 3.x.
The hardware revision of Mk2 can be found in two ways:
  1. In the About menu in version 4.5.0 and up: About → Version Info → Hardware = X
  2. The part number on the silkscreen of the PCB above the product label.
    Example: 7123B4646B.
As of software 4.2.0, there are some feature differences between the original (Mk1) and Mk2:
  • Mk2 hardware revision 'A'  and up supports:
    • DMX and sACN communication
    • Local UI configuration of load types, zones, spaces, presets, and sequences
    • Concert network configuration (supported in PCP Mk2 4.1.0 or later via Concert 4.4.0 (or higher)
      • PCP Mk2 4.0.1 can be configured offline in Concert 4.3.0 (or higher), and transferred to the PCP via USB.
    • UpdaterAtor software management (updating from 4.1.0 or later via UpdaterAtor 6.2.0 or later)
      • Update from 4.0.1 to 4.1.0 must be performed via USB.
    • All ERP, ERP-FT, and Sensor IQ power control modules and breakers
    • WebUI (added in 4.2.0)
    • 4 sACN sources per universe, for a maximum total of 16 sources
      • PCP Mk1 supported 6 total sources across 4 universes
    • Timeclock (added in 4.5.0)
    • Remote Error Reporting
    • Energy Management (ERP Mains Feed, Sensor IQ, or EchoDIN)
  • Mk2 hardware revision 'E' and up supports:
    • Echo station comms and power (added in 4.5.0)
  • Not yet supported, but planned for future software development:
    • Option Card firmware Updates Via UI
NOTE: An ETC Authorized Dealer can upgrade an existing rack from a Mk1 processor to a Mk2 can be done by ordering part number 7123K1028-RETRO, which includes all the necessary parts and instructions.
