How to Force All Outputs to Full on Echo Relay Panel Feedthrough
Description
You may find it necessary to turn on all outputs of a panel to full, or 100%.  This can be done easily on the processor.
The below process only works if the processor in your panel is an E-PCP Mk1 running software version 3.0.0 or higher.  The software version can be seen on the home screen in the bottom right corner.  Ex:The images below are from a processor running software version 3.1.2.
As of software 4.2.0, this feature has not been implemented in E-PCP Mk2.
  1. Locate the button on the processor to the right of the LCD screen with the image of a light bulb on it.
  2. Press and hold this button for a full 5 seconds, at which time all loads will switch on and output at 100% and the LCD screen will read: "All On.  All outputs driven to full. Press Enter or back to exit."
