Echo Zone Controller LED States
LED Color State Description Notes
Echo Relay Controller and Echo 0-10v Controller
Primary Off N/A Normal State In normal powered on state, there is no indication.  The LED is off by default.
Primary Red Flashing In process of Restore Defaults Red flashing LED will last for the duration of the restore and will then return to Normal State.
Echo SmartSpace Controller
Aux Input Mode Green Occupancy Mode Aux Input set up for use with 3rd party Occupancy sensor
Aux Input Mode Amber Photo Mode Aux Input set up for use with 3rd party Photo sensor
Aux Input Mode Red Disabled Aux Input use is Disabled
Aux Input Mode Red Flashing In process of Restore Defaults Red flashing LED will last for the duration of the restore and will then return to Normal State.
Echo Phase Adaptive Dimmer
Dimming Phase Green Solid Forward Phase Mode
Dimming Phase Amber Alternating (See Notes) Automatic Mode One amber blink, followed by one green blink: Auto Forward Phase mode
One amber blink, followed by one red blink: Auto Reverse Phase mode.
Dimming Mode Green Solid Normal Mode
Dimming Mode Red Solid Fluorescent Mode
Both LEDs Red 1 blink pattern Overcurrent will shut off until value is set to 0, then will resume normal use.  Load and wiring should be inspected to determine the cause of the overcurrent state.
Both LEDs Red 2 blink pattern Over Temp Will shut off until it cools down, then resume normal use. Unit should be inspected to see why it over heated.
Both LEDs Red 3 blink pattern Protective shut down mode Caused by multiple voltage spikes.  Could be an issue with the load, or could be too inductive of a load.  If highly inductive/Magnetic load, you should use the Echo Forward Phase Dimmer.
Both LEDs Red 3 blink pattern Protective shut down mode Caused by multiple voltage spikes.  Load and wiring should be inspected for source of voltage spikes.
