Unison Legacy Button, Fader and Relay Stations Repairs
Problems Cure
LEDs work when unbound but do not when bound
Reprogram Echelon Neuron IC or replace node PCB 7080B5041
Fader stations losing function completely
Replace or Reprogram U1 PAL 7080Z20XX-1.0 (7080Z2009-1.0, 7080Z2010-1.0, and 7080Z2011-1.0 are identical and interchangeable).
Node board looks dead. (If working or powering up, a red LED should blink when node board is plugged in)
Check filter L1. L1 may be open. If L1 has a red dot replace it with L9022-F per ECO 8542
Station not working.  Red LED on back is on solid Replace Echelon Neuron IC 7080Z2025-1.3 See NOTE
Station will not bind, no red LED blink when plugged in
Replace and reprogram Echelon Neuron IC 70780Z2025-1.3 See NOTE
or PCB 7080B5041
Satellite boards flickering on output
Socketed ICs U3 or U4
NOTE: If Echelon Neuron IC is replaced on anything other than a 5-Button station, it must be re-programmed or it will not function.  7080Z2025-1.3 is the newest type, and can be used as a direct replacement for 7080Z2004-12.  The Neuron ID of the station is permanently programmed in this IC, so replacing the IC will change the station's ID.
Reprogramming of any Unison Station IC must be done at ETC.
