Can Both the Primary and Secondary NIC on P-CCS be in the Same Subnet?
Symptoms
I want to be able to access both interfaces on my P-CCS on the same subnet. Can I set both NICs on a P-CCS to be in the same subnet?
No, both NICs must be on separate subnets. Additionally the NICs should be on different VLANs if both are connected to the same network switch, or they should be connected to separate physical switches that reside on different networks.
