Can a P-TS7 be connected to both PoE and 24vdc Aux?
Question
Can a wall mount P-TS7 be connected to both PoE (Power over Ethernet) and 24vdc Aux power? If so how does it decide which one to use?
Answer
Yes, both PoE and 24vdc Aux can safely be connected to a P-TS7. When Aux power is present, a component on the PCB turns off the PoE supply on the circuit board, so damage does not occur as a result of having two power sources connected.
