No faders function on a ColorSource console
Symptoms
  • Console boots fully
  • None of the faders are working
  • Bump buttons work
  • Touch screen works
  • You cannot access the Test Menu by holding down the 4 center buttons below the display
Explanation of Issue
A component monitoring the position of the faders has failed and requires replacement
Please contact your preferred ETC dealer or ETC Technical Services to set up a repair
