Channels Do Not Show Correct Playback or Sequence Color If Up in Channel Mode
If you set a channel to a level in channel mode and then bring up a playback or sequence without taking out the channel data, the channel will use HTP (highest takes precedence) to determine what levels to be at. RGB variant fixtures use additive color mixing, so red, green, and blue at full makes white light and lower levels of each color mixes to a different hue. So if a fixture is at full in channel mode but has a color in a playback, the channel will choose HTP and output the higher level for each color.
