ColorSource Console Restricted OSC Ports
The ColorSource AV Console uses specific ports for internal communication.
These following ports should be avoided as they will interfere and produce undesired behavior from the console.
Ports: 11011, 11012, 8001, 8002, 8012, 8013
By default, the Console is configured to use Ports 8006 and 8005 for sending and receiving respectively. When possible, the standard default ports should be used for OSC interfaces with the console.
