ColorSource Will Not Record Color Chip
In software version 2.5.0 and earlier, ColorSource cannot record color values set using direct emitter controls via the ColorMix tab to color chips. This issue was fixed in ColorSource console software 2.6.0 and higher.
Steps to Solution
If updating your console is not possible, you can work around this issue by setting your color via the color picker, then recording the color chip.
