Update the Full Speed I/O Card
- Last updated
- Save as PDF
Cobalt 10/20
             Component  |
             Firmware Version  |
             Keyboard Master  |
             1.1.0.9.0.0  |
             Fader Display Unit  |
             1.0.4.9.0.16 / 1.0.5.0.16*  |
             Independent Master  |
             1.0.1.9.0.5 / 1.0.2.9.0.6*  |
             Playback Master  |
             1.0.3.9.0.8 / 1.0.4.9.0.9*  |
             Full Speed I/O Card (with Phone Remote)  |
             1.4.2.9.0.5  |
             High Speed I/O Card (without Phone Remote)  |
             1.1.0.9.0.4 / 1.1.1.9.0.5*  |
Cobalt Programming Wing
             Component  |
             Firmware Version  |
             Programming Wing  |
             1.1.0.9.0.0  |
             Encoder Board  |
             1.0.1.9.0.9 / 1.0.2.9.0.10*  |
             Playback Master  |
             Full Speed I/O Card  |
             1.4.2.9.0.5  |
             High Speed I/O Card  |
Cobalt Motorized Fader Wing
             Component  |
             Firmware Version  |
             Fader Wing  |
             1.0.4.9.0.21 / 1.0.5.9.0.22*  |
Cobalt Light Server
             Component  |
             Firmware Version  |
             Light Server 10x2 Button  |
             1.1.0.9.0.1  |
             1.4.2.9.0.5  |
             Component  |
             Firmware Version  |
             Facepanel  |
             1.9  |
             1.4.2.9.0.5  |
General Update Requirements:
Updating the Full Speed I/O Card (Cobalt 10, 20, Programming Wing, Cobalt Light Server, Congo Jr, Congo Kid, Congo Light Server)
This process is only for the Full Speed I/O card. High Speed I/O cards should be updated following the procedure for Updating High Speed I/O Cards.
With the exception of the Cobalt Programming Wing, the Full Speed I/O card can be identified by the presence of a Phone Remote (RJ11) port. All Cobalt Programming Wings shipped without a Phone Remote port.
Step 1: Exit to System Settings or choose System Settings from the Welcome Screen.
Step 2: Navigate to the Update tab and select I/O Firmware Update.
Step 3: System Settings will send a command to the I/O Card to initialize update mode and wait for the I/O card to be detected.
Step 4: When connected, the I/O card will prompt for a firmware file and then ask to download the firmware. Select the following version and click {Download}
             IO_CARD_v1_4_2_9_0_005.SRC  |
Step 5: When complete, the I/O Downloader will return to the “Please Connect Console” prompt. Choose {Exit} to close the I/O Downloader.
Step 6: Choose {OK} to close System Settings and then power off your console/computer.
Step 7: This component is now ready for use on the next normal power up.
