Updating Firmware on Cobalt Family Consoles
Cobalt 20
Cobalt Face Panel (Keyboard Master) Firmware Update
Required Files
Before starting the firmware update procedure, make sure the following files are located on the root directory of a USB memory stick
File Name Description
14d5.0037_Keyboard_89_#.#.#.#.#.#.sx This is the actual firmware file
Update Process
This update process is accurate for Cobalt version 7.2.0 only. For all other versions, please use the manual update method described here: Manually Update the Cobalt Keyboard Master
Step 1: Exit to System Settings or choose System Settings from the Welcome Screen.
Step 2: Navigate to the Update tab and select the Cobalt Face Panel in Detected Modules of the Firmware Update section
Step 3: Insert the USB drive with the firmware file on the root of the drive
Step 4: Select the USB drive letter in the Firmware Files dropdown and click {Update}
Step 5: When complete, Choose {OK} on the Firmware Update Successful dialog.
Step 6: Choose {OK} to close System Settings.
Step 7: Power off the console for a minimum of 30 seconds
Step 8: Power on the console normally. The firmware is now updated.
Version History
Firmware Version Key Enhancements Distributed with Cobalt Version(s)
1.1.0.9.0.0 Improved USB communication 7.2.0
1.0.2.9.0.0 Initial Release Pre-Installed
Cobalt Fader Display Unit (Fader Board) Firmware Update
Required Files
14d5.0036_Display_#.#.#.#.#.#.afx.S19 This is the actual firmware file
Update Process
This update process is accurate for Cobalt version 7.2.0 only. For all other versions, please use the manual update method described here: Manually Update the Cobalt Fader Display Unit (FDU)
Step 2: Navigate to the Update tab and select the Cobalt Fader Board in Detected Modules of the Firmware Update section
Each Fader Display Unit (FDU) needs to be updated individually with a power cycle in between each item.
Version History
1.0.5.9.0.16 Bootloader Bug Fixes Available at ETC Service Center Only
1.0.4.9.0.16 Improved USB Communication 7.2.0
1.0.2.9.0.12 Bug Fixes 7.0.2
1.0.1.9.0.11 Bug Fixes 7.0.1
1.0.0.9.0.10 Initial Release Pre-Installed
Cobalt Independent Board (Independent Master) Firmware Update
Required Files
14d5.0039_Independent_#.#.#.#.#.#.afx.S19 This is the actual firmware file
Update Process
This update process is accurate for Cobalt version 7.2.0 only. For all other versions, please use the manual update method described here: Manually Update the Cobalt Independent Master
Step 2: Navigate to the Update tab and select the Cobalt Independent Board in Detected Modules of the Firmware Update section
Version History
1.0.2.9.0.6 Bootloader Bug Fixes Available at ETC Service Center Only
1.0.1.9.0.5 Bug Fixes 7.0.2
1.0.0.9.0.4 Initial Release Pre-Installed
Cobalt Playback Board (Playback Master) Firmware Update
Required Files
14d5.0038_Playback_1.0.3.9.0.8.afx.S19 This is the actual firmware file
Update Process
This update process is accurate for Cobalt version 7.2.0 only. For all other versions, please use the manual update method described here: Manually Update the Cobalt Playback Master
Step 2: Navigate to the Update tab and select the Cobalt Playback Board in Detected Modules of the Firmware Update section
Version History
1.0.4.9.0.9 Bootloader Bug Fixes Available at ETC Service Center Only
1.0.3.9.0.8 Bug Fixes 7.3.0
1.0.2.9.0.7 Improved USB Communication 7.2.0
1.0.1.9.0.6 Bug Fixes 7.0.2
1.0.0.9.0.5 Initial Release Pre-Installed
Full Speed I/O (with Phone Remote) Firmware Update
Required Files
Before starting the firmware update procedure, make sure the following files are located on a USB memory stick or were installed by the Congo application
CNGOJRIO_#-#-#-#.SRC This is the actual firmware file (versions <1.4)
IO_CARD_v#_#_#_#_#_###.SRC This is the actual firmware file (version 1.4+)
Update Process
Step 2: Navigate to the Update tab and select I/O Firmware Update.
Step 3: System Settings will send a command to the I/O Card to initialize update mode and wait for the I/O card to be detected.
Step 4: When connected, the I/O card will prompt for a firmware file and then ask to download the firmware. Select the correct .src version and click {Download}
Step 5: When complete, the I/O Downloader will return to the “Please Connect Console” prompt. Choose {Exit} to close the I/O Downloader.
Step 6: Choose {OK} to close System Settings and then power off your console.
Step 7: This component is now ready for use on the next normal power up.
Version History
1.4.2.9.0.005 Bug Fixes 7.3.0/7.3.1
1.4.1.9.0.003 Bug Fixes / Compatibility Updates 7.2.0
1.3.0.9.0.005 Initial Release for Cobalt Consoles Pre-Installed
High Speed I/O (without Phone Remote) Firmware Update
Required Files
14d5.0113_IO_Kinetis_v#.#.#.#.#.#.S19 This is the actual firmware file
Update Process
This update process is accurate for Cobalt version 7.2.0 only. For all other versions, please use the manual update method described here: Manually Update the High Speed I/O Card
Step 2: Navigate to the Update tab and select the Cobalt I/O Board HS in Detected Modules of the Firmware Update section
Version History
1.1.1.9.0.5 Bootloader Bug Fixes Available at ETC Service Center Only
1.1.0.9.0.4 Bug Fixes 8.0.1
Cobalt 10
Required Files
Update Process
Version History
Required Files
Update Process
Version History
Required Files
Update Process
Version History
Required Files
Update Process
Version History
Required Files
Update Process
Version History
Required Files
Update Process
Version History
Cobalt Programming Wing
Required Files
Update Process
Version History
Cobalt Encoder Board Firmware Update
Required Files
14d5.003b_Encoder_#.#.#.#.#.#.afx.S19 This is the actual firmware file
Update Process
This update process is accurate for Cobalt version 7.2.0 only. For all other versions, please use the manual update method described here: Manually Update the Cobalt Encoder Board
Step 2: Navigate to the Update tab and select the Cobalt Encoder Board in Detected Modules of the Firmware Update section
Version History
1.0.2.9.0.10 Bootloader Bug Fixes Available at ETC Service Center Only
1.0.1.9.0.9 Bug Fixes 7.3.0
1.0.0.9.0.8 Initial Release Pre-Installed
Required Files
Update Process
Version History
Required Files
Update Process
Version History
Required Files
Update Process
Version History
Cobalt Motorized Fader Wing
Required Files
14d5.003c_Display_HS_#.#.#.#.#.#.afx.S19 This is the actual firmware file
Update Process
This update process is accurate for Cobalt version 7.2.0 only. For all other versions, please use the manual update method described here: Manually Update the Cobalt Motorized Fader Wing FDUs
Version History
1.1.0.9.0.2 Support for Alternate Replacement Screen Available at ETC Service Center Only
1.0.5.9.0.22 Bootloader Bug Fixes Available at ETC Service Center Only
1.0.4.9.0.21 Improved USB Communication 8.0.0
1.0.0.9.0.11 Initial Release Pre-Installed
Congo Jr
Congo Jr Facepanel Firmware Update
Required Files
4320B4601revb1_#.hex This is the actual firmware file
Update Process
Step 2: Navigate to the Update tab and select the Congo Jr Face Panel  in Detected Modules of the Firmware Update section
Step 7: This component is now ready for use.
Version History
1.9 Removes "Jr" from LCD Logo to support Congo Kid Pre-Installed
1.8 Initial Release Pre-Installed
Congo Jr I/O Firmware Update
Required Files
Update Process
Version History
Firmware Version Key Enhancements Distributed with Congo/Cobalt Version(s)
1.3.0.9.0.005 Local RDM Support 6.4.0
1.2.0.9.0.005 Bug Fixes Pre-Installed in 6.2.x Consoles
1.0.0.9.0.027 Initial Release Pre-Installed in 4.0.x Consoles
Congo Jr Master Playback Wing Firmware Update
Special Note:
While the Master Playback Wing contains a single circuit board, the top and bottom halves are updated independently of each other while needing to match firmware between the two halves. Additionally, there are two revisions of the card (B and C) that require separate firmware from each other (but same version top/bottom).
Required Files
Revision B
4320B4602TOPB#_#.hex This is the actual firmware file for the top half
4320B4602BOTB#_#.hex This is the actual firmware file for the bottom half
Revision C
4320B4602TOPC#_#.hex This is the actual firmware file for the top half
4320B4602BOTC#_#.hex This is the actual firmware file for the bottom half
Update Process
Step 2: Navigate to the Update tab and select the Congo Jr Master Upper Rev X  in Detected Modules of the Firmware Update section
Step 6: Select the Congo Jr Master Lower Rev X  in Detected Modules of the Firmware Update section
Step 7: Select the USB drive letter in the Firmware Files dropdown and click {Update}
Step 8: When complete, Choose {OK} on the Firmware Update Successful dialog.
Step 9: Choose {OK} to close System Settings.
Step 10: This component is now ready for use.
Version History
2.0 USB Hub Update Pre-Installed or
Installed by Technical Services
1.8 PIC Chip Update Pre-Installed or
1.6 Initial Release Pre-Installed
Congo Kid
Congo Kid Facepanel Firmware Update
Note-Icon.png Congo Kid uses the same facepanel circuit board as Congo Jr.
Required Files
Update Process
Version History
1.9 Initial Release Pre-Installed
Congo Kid I/O Firmware Update
Note-Icon.png Congo Kid uses the same I/O card as Congo Jr.
Required Files
Update Process
Version History
Congo Kid Fader Firmware Update
Note-Icon.png Congo Kid uses (2) 1X20 Fader Wing circuit boards internally for the faders.
Required Files
4320B4605revB1_1.hex This is the actual firmware file for the top half
Update Process
Step 2: Navigate to the Update tab and select the ION 1x20 Submaster Rev B in Detected Modules of the Firmware Update section
Version History
1.1 Initial Release Pre-Installed
