What Happens When I Remove the BIOS Battery an ETCnomad Puck?
My console is being transported via air and the BIOS (CMOS) battery must be removed during transport.
The BIOS (CMOS) battery stores persistent memory for BIOS and the Date/Time/Location settings for your console. Removing this battery and putting it back in will cause these features to reset to defaults. Unless otherwise altered by an end user, the BIOS settings on your console are also the default settings.
The BIOS (CMOS) battery does not store data for the Show File Archive, however it is highly recommended that the Show File Archive is backed up onto an external drive before the console is transported.
Replacement Battery
CR2032 batteries are commonly available.  CR2032 can be sourced online (search for "CMOS battery 2032").  It is not possible to replace just the battery part of the CR2032W as they are manufactured not to come apart.
Note that CR2032W is not a standardised part, and batteries with that description may have a subtly different connector, and/or reversed polarity
CR2032W may be available from an ETC Dealer; the ETC Part# is BT161.
Please check your console and purchase the appropriate style of replacement battery.
CR2032
CR2032W
CR2032 CR2032W
n.b. connector orientation
Includes:
Eos Classic
Ion (Classic)
Element (One)
Gio
Eos Ti
Eos Apex Consoles
Eos RPU
Eos RPU3 (w/ DVI Connectors)
Ion RPU
Eos Apex Processor
Net3 RVI
Net3 RVI3 (w/out USB-C Ports)
Cobalt 20 & 10
Congo Sr
Congo Jr
Congo Kid
Includes:
Gio @5
Ion Xe
Ion Xe 20
Element 2
Eos RPU3 (w/ DisplayPort Connectors)
Ion Xe RPU
Net3 RVI3 (w/ USB-C ports)
Eos Remote Interface
Which battery does my console need?
All generations of the ETCnomad Puck should use a CR2032W battery.  That being said, that battery is very difficult to access in the Orignal and Second Generation Puck.  Please use caution if servicing.
Please note: If you have the first generation (Original) of ETCnomad Puck, the two pins of the spare battery (BT161) needs to be swapped. Do not plug in a battery that has the pin orientation like above!
What puck generation do I have? -> please a look at this article
