Removing Element Fader Ribbon From Monitor
Is there any way to remove the fader status boxes at the bottom of monitor on the Element console?
The fader status boxes on my monitor for my Element console are gone.
The Fader Ribbon is shown by default and is always present if running software previous to v2.6.0. However, if the console software is v2.6.0 or higher, this can be enabled(shown) or disabled(hidden) in the console settings. To enable or disable the Fader Ribbon please follow the steps below.
- v2.6.0-v2.6.4: Press "Displays" to show the File Browser, then navigate to Setup > Desk Settings. Select "Displays" settings on the left and click "Display Fader Ribbon" to enable or disable this feature.
- v2.7.0+: Press "Displays" to show the File Browser, then navigate to Setup > User Settings. Select "Displays" settings on the left and click "Display Fader Ribbon" to enable or disable this feature.
