How to Map a Grandmaster Fader / Blackout on Element 2
Question
How do I map the Grandmaster function to a fader on an ETC Eos Family console that does not have a dedicated GM fader?
Answer
You can map the Grandmaster function to a virtual fader or wing fader via Tab 36 - Fader Configuration:
  • Open Tab 36
  • Select the function box for the desired fader (may say something like 'unmapped' or 'sub X' already)
  • From the dropdown menu, select the function option
  • From the function dropdown menu, select 'Grandmaster' option
  • The fader will now function as a Grandmaster.  On the console both bumps must be depressed together to activate BLACKOUT.  On the virtual fader module, only the bottom bump must be clicked to activate BLACKOUT.
