Apex Button Module OLED 1x10 Target Key in Bootloader Mode
Apex OLED 10x1 Button Module firmware is missing or needs to be reprogrammed
In bootloader mode, the 2nd and 3rd keys appear "snowy" or with "static":
In Eos Shell > Maintenance > Firmware Update, the Apex Button Module is listed with the words Bootloader and warning
"Cannot update other devices while any component is in bootloader mode"
This may occur due to a defect with the Face Panel Test in Eos v3.2.6 to 3.2.8: OLED Display Default Boot Image Bootloader on Eos Apex Consoles - Electronic Theatre Controls Inc
Power the Apex console off and back on to attempt recovery.
If the Apex Button Module is still listed in Bootloader mode after a power-cycle, contact ETC Technical Services.
