Internal Display Brightness Backward Compared to Slider On Eos Apex Consoles
Apex internal display brightness is backward compared to slider
When changing the brightness level of the internal displays on an Apex the brightness should be the same between displays and the brightness should match the level of the slider. Holding down the displays key will bring up a shortcut to brightness control of the internal monitors.
If you bring the internal monitor slider down and the brightness increases or in reverse then this may be an issue with the display card on the monitor.
Contact ETC Technical Services
