Internal or External Screen of Apex Console goes dark
One internal or external screen of an Apex console suddenly goes dark during regular usage. The backlight of the screen may remain on, but nothing appears on the screen. The screen may remain dark until the console is power-cycled, or it may go blank for a few seconds, then recover.
Explanation of Issue
There have been occasional reports of this issue in Apex consoles. Known causes include:
- Interference from 2-way Radios (Using a Radio (Walkie-Talkie) Near My ETC Equipment Causes it to Behave Strangely)
- Static ESD discharge, as when plugging in a USB cable or thumbdrive
- Moving the screen (causing an internal connection to flex or become loose)
- Firmware issues on the monitor transition cards (consoles manufactured prior to January 2024)
If the screen returns to normal operation after a few seconds, it has recovered from the interruption and should continue to operate normally. No further action is needed.
If the screen does not return to normal operation after 60 seconds, proceed with these troubleshooting steps:
Record the following information:
Once it is safe to exit out of Eos software:
| If, after that testing, the issue is persistent, please email eos@etcconnect.com or call Technical Services to determine if replacement monitor transition card is necessary. ETC Technical Services will ask for the serial number of the console and any other notes you have taken on this issue. |
