Apex Level Wheel Replacement
There are multiple issues that can cause the level wheel on Apex to be difficult to turn. A new design of this level wheel fixes many issues. This article describes the process of how to replace the level wheel assembly.
Parts/Tools needed
4450K1060 - Apex Level Wheel Kit
5.5mm nut driver
1/4" hex wrench (allen key)
Opening the Control Panel
Replacement Instructions
Using a 5.5mm nut driver, remove the 4 nuts holding the level wheel down.
Remove the upper and lower light blocker brackets, then remove the level wheel assembly.
Take the new level wheel out of the packaging.
Find the side with the magnet on it, this side will be facing the sensor.
Install the level wheel with the magnet facing the sensor.
Press in the upper and lower light blockers. You may need to squeeze the metal to get them to align with the studs.
Install the 4 nuts to secure the assembly.
Test the feel of the level wheel rotation and test the functionality in face panel test.
Close and lock the console by following the opening steps in reverse
