ARRI Skypanels, ColorPicker, and Eos Software
In default mode, the ARRI Skypanel may not respond to the Color Picker in Eos, but only change Color Temperature and Tint.
These fixtures have a parameter called Color Cross Fader (Col Xfd) that must be engaged to allow direct color mixing rather than simple color temperature control.  If this is at full then the color picker can be used.  If it is at zero you will only have color temperature and tint control.
  1. In ML controls look for Col Xfd parameter
  2. Set it to Max
  3. Use the Color Picker as desired
